Well I have had the battery on the bench with a charger with a 'refresh' mode specifically designed to recover AGM batteries, after 23 hours it has added 50ah to the battery, when I pause the charger, applied a load to the battery of 60w for 5 minutes the battery voltage reads 12.11V
I have resumed the refresh mode and hopefully I have managed to save the battery and will refit to the van tomorrow at some point.
Just to be sure I have reset all Victron components in the van and will adjust the settings when I refit the battery based on a combination of your advice, and will see if the battery actually behaves how it should.
Thanks as always for all your advice - if this is no good I may just cut my losses and get a Lithium battery and then change the Victron components to their default Lithium settings - am I ok with the default settings or should they also be adjusted really? I have Victron MPPT solar, Shunt and B2B and Victon IP22 AC charger 15a version.
