ThanksMine was a 516-3. It doesn’t support lithium.
Ignore the campsite ampage, that's a red herring.Getting my self a bit confused on which Victron charger to replace the CB516-3
The CB516-3 has a output of 16A Max
Will need to double check the wiring to see what size it is.
I have a 325 Watt Solar which is the main supply of my electric along with DC / DC Charger
90% of my trips are off Grid , however I tend to plug in at home and then turn the fridge on full , for a few hrs to get it cold before start of a trip.
As for the battery , thinking of Fogstar Drift 12V 300Ah Lithium Leisure Battery
I know it is a lot of money but would fit in , and would add a extra 100Ah to my set up
The other option would be Fogstar Drift 12V 105Ah Lithium Leisure Battery X 2
Would be sliglty cheeper and would be easer to get in due to weight
However would still give me 200Ah which is my current setup.
The downside of having 300Ah is that the solar pannel is not going to keep up
Therefore I was thinking of getting Victron Energy Blue Smart IP22 Bluetooth Battery Charger - 12V 15A, 1 output
Which is not a bad price
However it does have a Near-silent fan
Someone mentioned IP65 charger @ginkster
Maybe Victron Energy Blue Smart IP65 Charger - 12V 15A
It is more expensive than the IP22
Does not have a fan , so will run silent
The other option but I think this is a overkill and would have to replace the wiring I suspect.
Victron Energy Phoenix Smart IP43 Charger 12V 30A
At nearly £300 makes it a very expensive option.
I think most UK campsites have 10A or 16A supply so dont think the IP43 makes any sense
Sorry for so many questions , I realy do appreciate people's time and thoughts.
And definitely fit an Ablemail to keep the starter topped up.Ignore the campsite ampage, that's a red herring.
15A is the 12v output, at 240v the mains input will be less than 1 amp.
The IP22 and IP65 are essentially the same, just different liquid resistance ratings. Go for the cheaper one if it is going to be secure and protected from water.
I was recommended the 30A based on having 230Ah of Fogstar, but the 15A will work fine.
The Victron IP22 15A is also fanless and silent, I have one.Getting my self a bit confused on which Victron charger to replace the CB516-3
Re. DC-DC Amps v Mains AmpsIgnore the campsite ampage, that's a red herring.
There is an IP22 12V 30A charger too....Therefore I was thinking of getting Victron Energy Blue Smart IP22 Bluetooth Battery Charger - 12V 15A, 1 output
Do you even need a mains charger? Unless your fridge is massively inefficient (I mean massively!) then any power it uses for the few hours to cool down will be easily replaced by solar and/or the DC-DC charger as you drive to camp. If you’re mostly offgrid then a mains charger is just a waste of money and space.Getting my self a bit confused on which Victron charger to replace the CB516-3
