Round Interior 3w Led Lights With Onboard Touch Activation In A Transporter
Dellmassive
VCDS User
Moderator
T6 Master
Round Interior 3W LED Lights With Onboard Touch Activation in a T6Transporter . . .
does anybody know if this kit will work in the back of a Transporter if "the power feed is taken from an existing rocker light in the roof"?
Basically will they turn on/off with the doors like the OEM rocker lights . . . or do you need to touch the master light every time to switch them on? have they got a memory? as in on/off every time the doors are opened.? so if you leave them off, they stay off? and if you set them on they will come on and off with the existing rocker lights.?
You need the ones in the shop without the touch switch, if connected correctly to the existing light they will come on and off with the doors.
Great. thanks @Deaky .
I used a few sets of these on the old T5.1, they worked very well in the rear (low power, didnt get hot, great light output) . . . .wondering if the T6S ones will be better,?
