Hallo folks.
I thought I'd post an update on my fun journey with the 102hp T6 van@125,000 miles. To save any rereading of this now quite long thread: a blocked EGR and cooler; mechanic chose to mechanically clean instead of replacing EGR/cooler. EGR/cooler then failed and pulled in a load of coolant, hydrolocked the engine when stationary but it had been driven on a dual carriageway. Engine then ran rough - especially being hesitant around 1500-2000RPM. Vibrations, shaking. Nothing violent, but undeniably there. The main thrust of thread before this was trying to determine the cause of the rough, though a bent rod or similar.
I called a lot of places and didn't manage to find anyone willing to take on the diagnostic side of things and measure the cylinders to determine bend rods or not. A couple of businesses were willing to put a new/reconditioned engine in, but at costs fairly in excess of the value of the vehicle. No one was up for making the measurements or doing much of anything that didn't involve replacing the engine.
In the end the mechanic (sound enough) responsible for the initial problem agreed to resolve his error.
Initially he put a fresh set of injectors on the engine to rule out fouled injectors from the coolant ingress. Apparently couldn't then get the engine to run at all.
Depth gauge at TDC was done with no discernible problem - apparently biggest difference was 0.04mm which is within tolerance.
Without agreeing anything with me, he proceeded to remove the engine and more or less take it to bits!
Block and valves were sent for testing - no issues. Injector mounts replaced, head gasket replaced, a bunch of other components I didn't recognise the names of were checked or replaced.
In short - couldn't find a discernible problem.
Put it all back together and then messed about with another two new sets of injectors, swapping them around. Apparently could get some to fire, then not others. I am a little hazy on the detail here - but it seems to have been a mission. Something about VW engines and accepting new injectors?
Eventually returned the van this week - it's supposed to be fixed. It does idle better now.
However - similar problem remains around the 1500-1800 RPM range.
Frustratingly, the issue with C4 seems to be resolved, but C1 remains an outlier in terms of torque. There are two pairs of images from before and after surgery - one pair is warm idling, the other pulling on the motorway.
Regrettably, some new fault codes now present on VCDS (but not yet triggering a light) - low refrigerant on the (still working) AC, and problems with the battery regulator.
I know this is probably getting a bit old - but I figure it worth a post to see what you folks think?
I'm going to attach a scan, blockmap (running and not) and a journey with a bunch of data points logged in case
@mmi fancies a poke
I suppose it's possible that the C4 injector was fouled while C1 has a very small bend to its rod that has escaped detection?
I'm wondering back to
@DXX 's suggestion of a poorly performing crank sensor and will see if I can check this with VCDS or just replace it. to rule it out.
If anyone has any suggestions on where to even think about going next with this - I am all ears!!
When idling cold and bringing revs up to 1500-2000 - the vehicle shakes about and the engine is't happy.
It's not so bad when warm.
Here's a before and after of a warm idle:
Here are a before and after of pulling on the motorway:
