Heya - thanks for the response.
Yeah, CXGB engine. I can’t answer your ??? with much certainty. This is all fairly new to me and I was simply trusting the professionals.
I think the engine is still consuming a small amount of coolant, the reservoir is 1 cm lower than it was when I topped it up after the new EGR was put on.
The garage cleaned the blocked-solid EGR and put it all back together without consulting with me. I’m not a mechanic and I trusted them - so didn’t think it that strange (although as the original seller of the van would be paying for the work, I had preferred a replacement).
They told me it has a ‘rough idle’ which I’m pretty sure it didn’t exist before.
I collected it, and drove half a mile at 20 mph before white clouds of smoke. I took it right back. A junior mechanic decided this was the DPF regenerating now that it had correct flow He drove it away to “clear it”. I believe it would’ve been driven up to 60 or 70 mph on a dual carriageway for about 10 minutes. On returning, he idled the vehicle which then stalled. He could not restart it.
Chief mechanic then came out, had a look and then became very sad. He told me coolant had been pulled into the engine (about half the visible reservoir was missing).
At the time I had no idea what this really meant.
The garage apparently then flushed, cleaned, replace replaced with new EGR from VW, tested - but I don’t know the details.
This business is very well thought of, the mechanic is fastidious and seemingly honest and competent… I’ve been given no reason to not trust them until now.
Since then, van has the rough idle and weird vibrations at around 2000 RPM. Injector deviations average 10 µs with maximum readings from separate injectors between 40 and 70 µs.
It’s going back to them this week so they can put the issue right. I might just ask that they replace the intercooler (given the history of cleaning components) and send the injectors away for testing. I told them I was concerned the hydrolock could have damaged the rods, but this was dismissed as not possible (only the starter motor). None of the places I have contacted seem very interested in helping… south west Wales. Perhaps they recognise this as too much trouble.
