Roof Light Bar Recommendations?
Rob The Daddy
Hi Everyone,
Can anyone recommend a light bar and brackets to go on top of a T6 Transporter please?
Last weekend, I drove to Danby Castle for a mate's wedding, and had to drive through the Yorkshire Moors, last Saturday at midday in thick fog; and in the evening at around 8.30pm (again in fog), and it was no joke with standard lights etc!
Cheers!
Lazer Lamps
A few have them on here.
Fitted in the front grill.
Seen them fitted on the roof too.
@Base1388 springs to mind on his rig.
This looks awesome…
So does this…
Hi Everyone,
Cheers!
High level lights are no use in fog, all that happens is even more light will be reflected back at you. Fog lights are mounted low and have a wide spread of light to illuminate the road surface and edges.
Theres also the Road Vehicle Lighting Regulations to consider. High level lights can only be used as main beam, or auxiliary lights which must extinguish when headlights are dipped, IIRC. Having said that, from what I’ve seen Lazer lights are great auxiliary (long range) lights.
Hi Everyone,
Cheers!
High level lights will be worse than useless in fog.
This looks awesome…
So does this…
Oh thank you! Liking the Urban look. Just need to justify to the wife about the cost
