So, after 5 years I've replaced my AGM leisure battery with a shiny Roamer.
During lockdown I added solar and a CTEK 250 SE charger.
When new I got fitted professionally a Victron mains charger.
I've got factory heated seats and the original leisure battery and split charge relay.
It all works fine. However, the Roamer wasn't the drop in replacement I was expecting as it's taller and needs to be fitted on its side.
This weekend I want to tidy up the install and rats nest of cables. Yes, I have temporarily used old battery terminals as bus bars, protected by plastic sandwich bags. Yes, the Roamer isn't fastened down. I do have ratchet straps, proper bus bars, cabling, terminals etc to sort that this weekend.
Now, I've seen some of those sick seat base installs on the other thread. They don't seem to be messed up with the OEM wiring for what I assume is the heated seats and split charge relay like mine. See attached pic. So, my question is can I remove any of this to create more room?
By the way, I wish to keep the heated seats
