Seems a fair comment.If you want to minimise height for parking barriers etc, get a flexi.
If you want to maximise reliability and ease of replacement, or watts per pound spent, get a rigid.
If you care about the aesthetics, obviously personal preference, but this is why many people would fit flexi.
I am yet to fit a panel to my van but have thought about this for some time.
I listed my priorities and have decided from that, I plan on spending a lot of time in my van after I have finished building it. - not hooked up.
My priorities in order
I have decided a rigid panel is best for me.
- Performance
- Fixability, servicing, maintenance
- Aesthetics
- Cost
- Vehicle height
- Upgradable
- Ease of install
- Affect of MPG/Road noise
Pro's
best performance per £
Easiy replaced if broken, can swap out for an upgrade.
No risk of damage, excessive clean up when replacing panel
Low cost
Con's
Aesthetics are lacking but with cost of panel being low I can spend money on making it look better (I have seen really good examples on this site)
Height is somewhat an issue but I do want roof bars on my poptop so I plan to fit the panel without increasing height further
MPG/Road noise will be degraded
I sent the renogy's back and fitted a single 480w panel.How did you get on cavester? I'm looking at a Renogy Shadowflux 200w fixed panel to replace my twice failed PVLogic flex planels which were Sikaflex'd to the poptop and also wondering if the plastic corner and side brackets would be man enough for the job.
That’s a very smart install! What brand of panel did you go for if not the Renogys?
Hi! Your setup looks absolutely fantastic.It's an Aiko Neostar 2S. Much more efficient than the Renogy's and more bang for buck at only £80 when I bought it (they have gone up slightly now I think).
Did the same myself last year with the 150W firefly panels, 110cm length, mounted width-ways on existing rails. Works a treat and no issues with the (Reimo) poptop. On a hot day, elevated, I get just under 20A into the battery.Thanks,
I came up with the same logic tbh. I've ordered 2 x 175w renogy rigid panels to mount width ways towards the rear. Hopefully the pop top will take the added weight.
I'm now trying to determine the best way to fix them. I've ordered the plastic corner and mid plastic brackets but I'm hesitant to want to glue them to my painted roof.
Is that air deflector a supplied part or bespoke?
no, just something I picked up off Amazon. Put one at front and rear, it deflects air flow and stabilises the panels.Is that air deflector a supplied part or bespoke?
