Even with the banding removed it still doesn't quite pick up the towball, does it?To hitch a trailer on accurately....not for parking.
There’s no coding on a T6, not sure bout T6.1 thoughCheers folks. Im going to alther the angle just to see what the effect is. Trouble is the camera housing wont be sealed against the paintwork so another issue created by solving one.
@Deaky any ideas about the coding potential??
There is coding to do with the camera on a T6.1, I had to do it on mine to get the retrofit working.There’s no coding on a T6, not sure bout T6.1 though
Highline cameras have a module that needs coding, lowline cameras have no code able module.There is coding to do with the camera on a T6.1, I had to do it on mine to get the retrofit working.
I bought my camera here;
There's 2 camera options 'high line' and 'low line', I bought the 'high line' one. I'm not sure what the factory fitted one is.
Have a look here;
T6.1 Retrofit Reversing Camera
Hmmm... last time I tried to code a camera into a headunit the option wasn’t there in VCDS to activate it, I looked around at other installers and even they were stating that the cameras could only be retrofitted to certain headunit models.... Even the base model can have a camera, using the...www.t6forum.com
See if you can flog the lowline and buy a highline? If the looms are similar it's an easy job?Great replies folks. Its a lowline camera on a 6.1. It doesn't have the towbar option as T6Jay mentioned. Bloody frustrating as its the only reason I had the camera.
I'll have a good look on Saturday when I have the time and keep you updated.
