retrofit rear camera
paul600rr
Hi can anyone recommend in the Nottingham area a good fitter who can supply & fit me the rear reversing camera to my T6. are the low line cameras alot better with the moving lines worth the extra money from the OEM VW camera ?. anyone got one fitted
cheers
What head unit you got? If it’s the stock one not sure you can use anything but the OEM camera.
I don’t rate it that much but it works. Not great resolution and the lines are static and weirdly placed.
I’m in Nottingham and fitted my own so could help/advise you if you go that route. It’s not hard but I cut the hole with a dremel as I can’t be trusted with real tools! The cabling is easy. Just need VCDS then (which I borrowed from amazon :).
Si
