Retrofit 360° PDC / PLA on T6
Jan_B
Hello,
I'm currently retrofitting the 360° OPS view in my T6 without PLA.
Ciclo demonstrated how to do it in his Polo.
https://uk-polos.net/viewtopic.php?
Now I'm facing a problem...
When the sensors aren't connected, I get the 360° OPS view in Discover Media.
However, as soon as the sensors are connected, the view disappears and the normal 8K view appears.
Wirring loom and sensors aren’t faulty.
Each sensor gets +12v and signal.
Vdcs shows the distance of each side sensor corretly!
The fault memory is empty except for the known steering column fault.
Maybe one of you has an idea…
Where is the small change to get the view in Discover Media...?
@Jan_B being a pioneer is a privilege. Great work! Once the Electric Power Steering retrofit is complete, the PLA will function naturally as part of the new system :whistle:
Purchased on eBay:
Once received:
It landed on the table:
Got it flashed to 1K8 919 475D:
Uploaded CADDY MAXI data set:
Caddy Maxi MK4 dimensions are the closest to T6 SWB so PLA/360° PDC should function in the most accurate way.
It has only 6mm longer wheelbase and 30cm wider turning circle.
VCDS ADVANCED ID:
Code:
Address 10: Park/Steer Assist
Control Module Part Number: 1K8 919 475 D
  Component and/or Version: PARKHILFE PLA H12 0480
           Software Coding: 0000000000
            Work Shop Code: WSC 00000
                      VCID: 3B22CE0BF3E9EE02DA1-806E
Advanced Identification/FAZIT
     Serial number: 39431628101685
     Identification: ATW-001
     Revision: --------
     Date: 09.10.16
     Manufacturer number: EC07
     Test stand number: 0164
Flash Status
     Programming Attempts(application): 1/1/1/1/1
     Programming Attempts(data): 1
     Successful Attempts(data): 1
     Flash Date-Workshop ID-Status:
     00.00.00 00000 000 00000 (OK) | 26.05.03 00200 011 01357 (OK) | 26.05.03 00200 011 01357 (OK) | 26.05.03 00200 011 01357 (OK)
     Flash Tool Code(data): 12345 123 12345
Misc.
     Hardware number: 5Q0 919 298
     Workshop System Name: J791
     Workshop ID (Adaptation): 00000 000 00000
     Workshop ID (Coding): 00000 000 00000
     Equipment/PR Code: 000000000000000000000000
     Dataset Number: -----------
     Dataset Version: ----
     ASAM Dataset: EV_EPHVA2CVW364GP00
     ASAM Dataset Revision: 001010
VCDS Info:
     Labels: 5Q0-919-298.clb
     ROD: EV_EPHVA2CVW364GP00_VW36
And set some initial coding:
I installed the Caddy Maxi data set last friday too.
I think it works perfectly!
The grey and red bars displayed correct distance between obstacle and vehicle in Discover Media.
Also nice match with highline RVC system
I will compile the correct pin assignments in a table and make it available here; I hope tomorrow
Here are partnumbers that I used:
- PLA unit: 1K8919475B flashed to 1K8919475D with Caddy MAXI data set
You can also use 5Q0 unit like @Robert
- Front sensor brackets satin black: 7LA 998 399 9B9 (only satin black available)
- Rear sensor brackets satin black: 7LA 998 397 B
or
- Rear sensor brackets primed: 7LA 998 397 B GRU
- Seals black: 5Q0 919 133
- Sensors rear side: 5Q0 919 475 B
- Sensors front side: 5Q0 919 497 B is original T6.1 but I used the same as rear!
If you are using the same sensors at the front and rear, you will need to cut off this small section from the front bracket:
I used them because I know that these sensors are working 100%.
- Connectors sensors: 4F0 973 703
- 10m wirring 0,35mm2 bl rear left
- 10m wirring 0,35mm2 gn rear right
- 10m wirring 0,35mm2 gr/bl front right
- 10m wirring 0,35mm2 vi front left
- for sensors +12v and ground I used red and brown wires. Power supply I got from the other PDC sensors
- Mcon 1.2 pins with seals for PDC connectors
- MQS 0,35 pins for original PDC connectors for PLA unit
- 1N4007 Diode for PLA button trick
Mounted sensors in brackets:
Pin assignments for PLA unit with adapter wirring harness MQB to PQ
The green lines are the new wires in original PQ connectors.
My Ali Express adapter wiring harness MQB/PQ is fully occupied.
The PLA button wire goes from 9 with diode to ground.
I'm not sure whether the sensors are powered by terminal 15 or terminal 30; I've labeled them as terminal 15.
+12V and ground are already taken from the existing sensors anyway.
Over the weekend, I got a second bumper—this one from a Highline Multivan—and upon closer inspection, I realized that it differs from the Transporter bumper. The space available for the PLA sensor is significantly smaller than on the Transporter bumper—but see for yourselves.
Transporter bumper:
Highline Multivan bumper:
On the Transporter bumper, there is much more vertical clearance; consequently, on the Highline bumper, the PLA sensor can only be mounted at the same height as the existing PDC sensors.
The holder would need to be adjusted slightly for this.
Today I did some tests with multivan bumper…
With this position, the PLA sensor is positioned centrally relative to the existing PDC sensors.
The curvature of the aperture in the lower right section is quite pronounced. It might be better to adjust the dimension by 1–2 mm or to modify the mount slightly further.
The dimensions are measured from the outer edges.
I definitely really like the positioning—at the same height as the other sensors.
@Robert let me know where you plan to place the sensors. You might find an even better position.
Retrofit completed successfully.
Thank you @Jan_B for your motivation.
20260606_224748(4).webp20260606_224748(5).webp20260606_224748(6).webp20260606_224748(7).webp
Rather than thinking of it as a full PLA (Park Assist) system, it is more accurate to view it as a 360° PDC (Park Distance Control) setup.
Here is what I have observed so far:
- Automatic Park Pilot Activation functions exactly the same as it did on the previous 1K8 PDC module.
- The new PLA/360° PDC system automatically turns off when the DSG is shifted into Park (P).
Automatic maneuver braking still needs to be tested.
Following up on my recent post about the successful PLA retrofit, there are a couple of important things I need to add.
First, a massive thank you to @ciclo for your incredible dedication and attention to detail.
I also want to officially apologize to @Lez78. When you first proposed this retrofit for the Transporter T5/T6 back in January 2022, I was pretty skeptical. You were right all along!
And finally, as is tradition, below is my typical show-off video. Enjoy!
The PLA/360° PDC effectively uses 16 zones all the way around the vehicle (4 front, 4 rear, and 4 on each side).
Naturally, the front and rear are covered by 4 physical sensors each. The sides, however, are covered by only 2 physical sensors and 2 virtual zones in between (effectively covering all four doors). When the PLA/PDC system is activated, the virtual zones need to be generated on the Discover Media screen, which is done by moving the vehicle forward or backward. During this movement, the system also factors in the steering angle to calculate whether obstacles you pass are getting closer to or further from the sides of the vehicle.
An interesting observation is that once this projection is complete, opening any door cancels it, and the system has to recreate the projection coverage by moving the vehicle again.
Today I installed the original PLA sensors from T6.1 5Q0919297B in front bumper and they‘re working too!
You need other connectors but no cutting on sensors like 275B necesarry!
Connectors:
The connector coding is different:
