Sold InCarTec Volkswagen Rear Camera Add On Interface Adapter / 27-300 / VW T6 / £60
bobbybasic
£60 delivered
This is an adapter for adding an aftermarket reversing camera to your factory OEM head unit.
This has recenty been taken out of my VW T6 and has had very light use.
The interface is boxed and comes with instructions.
Any question please feel free to get in touch.
Details
Add a reverse view NTSC camera to select Volkswagen vehicle models with Composition Media/Discover Media (MIB STD2 PQ/+NAV) systems.
This interface is a camera add on kit which allows you to add an aftermarket rear view camera whilst retaining the use of your factory head unit. This harness has a built in interface to give ignition power and a reverse feed to the camera.
Compatible with following vehicles:
Suitable for the following Volkswagen vehicle models with factory OPS, MIB STD2 PQ/+NAV, Composition Media/Discover Media, 1x SD Slot vertically left or 1x SD slot each vertically left and right and CD drive above the 6.33 inch monitor:
MAN - TGE (2017 >)
Volkswagen - Amarok (2018 - 2022)
Volkswagen - Beetle (A5) (2011 - 2019)
Volkswagen - Caddy (3rd Gen Facelift 2.0) (2016 - 2020)
Volkswagen - Sharan II (2010 - 2022)
Volkswagen - Transporter T6 (2015 -2019)
Volkswagen - Transporter T6.1 (2019 >)
Compatibility notes:
NOT compatible with 1K8035150_ head unit models. The head unit model number can be found by accessing the info/about menu on the head unit. 27-300 will work with most Composition Media head units, but there are some that do not accept a camera input at all.
NOT compatible with the following model numbers XXX035820A, XXX035820, XXX035819A, XXX035819 or XXX035812.
The head unit model number can be found by accessing the info/about menu on the head unit to check before purchase.
Please see pictures showing example images of the VW Composition Media and Discover Media radios from VW T6 and Caddy vans that this interface is compatible
