Reset various system procedures
Andpopse
Is there a Thread out there to add these simple procedures for resetting systems that have stopped working ?
I’ve learnt that turning the steering full lock each way and opening and shutting bonnet Clears faults after battery change.
Pressing window down for 3 secs then up for 3 secs with engine running, resets one touch operation and resets folding mirrors on fob.
Above apply to T6.1
There must be others that we can all share ?
Cheers All
DSG gearbox : learned behaviour and clutch bite point reset :
turn ignition on (do not crank)
Press accelerator pedal to the floor and hold it there,
wait approx 20 seconds (you should feel a click through the accelerator pedal, you may hear a noise from the gearbox)
Reset Done.
start and drive as normal
