Reset tyre pressure warning - without the original radio
smilie121
VCDS User
The van's tyre pressure warning light came up and I no longer have the original VW head unit - changed to a Kenwood 7190 from @Absolut5
I have checked the MFD (buttons on the stalk) and do not appear to have an option to clear it
Do you have a physical button hiding in the glove compartment? On ours, you hold that down whilst electrics on but engine not running to reset it.
Tyre pressures are controlled via the dash display and steering wheel buttons not the radio so should t make any difference that the radio is gone
@Pauly
The option is not in the MFD. I just retro fitted a MFSW and yet to code the buttons in. But scrolling through the menu via the stalk brings no such option. I did reset it once with the factory unit. First time the light has come on since fitting the radio some months ago
Oh, might be trickier with a retro-fitted wheel that’s not got all the functionality yet.
Have you got carista or something, does that reset tyre pressure warnings?
@Pauly
I have only seen tyre pressure controlled with wheel/stalk buttons and where these are not factory fitted an extra button in the glovebox would be the norm ?
I know! The gut i bought it from used a carista on the menu to get digital display
I have an OBDeleven Pro but doesnt appear to have anything for turning menu function on
