Welcome to the group
@AV Elements.
My first bit of advice would be to remove your full address from your Avatar detail. There are too many unscrupulous buggers out there.
Have you got the H4 or H7 headlights? You have a couple options ultimately. 1) upgrade the H4’s to H7’s, they are a simple plug and play swap over,
@Pauly can supply. It’s really not worth putting upgraded bulbs in the H4’s as the reflector pattern of the unit is pants. If you want LED’s you have 2 further options. 2) Rhere a couple of places now starting to offer an LED upgrade (such as Transporter HQ) however this is just an LED DRL strip with H7 dipped and mains. Or you can go for a full OEM LED upgrade, again Pauly can supply but if you want to do it properly you’ll need the auto leveller components that attach to the rear antiroll bar; and this starts getting expensive. The OEM LED’s will give you the brightest whitest light of the range.
As to you stereo woes, place a call to Absolute Audio in Wiltshire (or
@Absolut5 as he is known on here) not much he doesn’t know when it comes to ICE and also does some awesome line outs as well.
Depending on your willingness to travel and exactly what you want to do Upholstery wise, Vision Upholstery in Shropshire is a good starting point. A few chaps have had theirs done there and results look pretty good.
Best of luck, hope you’ve got deep pockets.
