Replacement abs module
patstone
Because my abs is damaged i can not get abs codes, is there another way to code new abs module . 2016 vw t6 t30 140hp euro5 caac engine
It sounds complicated to me never coded abs before all new to me,was hoping I would be handed a number and just stick it in, thanks for the info
Only other way with out existing code is ODIS
All you need is this VCDS. Post a full auto scan of your car, then you will need to answer a few questions and I will try to help you with coding
