Removing reversing camera via VCDS RCD330
Walshy83
Anyone got any ideas how to remove the reversing camera feature via a VCDS? this message comes up after it goes into reverse.
Its a RCD360 head unit.
Assuming you have a camera installed them
Module 5F - byte 19 - bit4
Module 10 - byte 10 - bit 5
Untick the boxes that say RVC installed
Not the complete story. Its an RCD330 plus.
came to me for programming but the head unit is from a t5.1 and not recognised by his can gateway and therefore not able to be programmed.
it needs to go back into a 5.1 and then have the camera coded out.
also, the can gateway has a permanent error as it has no recognised radio installed.
Ah, why do people only give half the info :rolleyes:
If this message appears does it mean that it is correctly coded to work ? Just fitted an RCD360 and get this message when selecting reverse , haven't connected a reversing camera as I have a mirror mounted set up already.Will fitting the camera that Travelin-lite advertise for this unit ,work straight off and clear the warning or is there the chance of more coding needed? Not interested in paying out another £40 only to find I need VCDS to make it work ,only have Carista I'm afraid :thumbsdown:
