Removing front bumper
Briston
Please forgive me if this has been covered before,
But does the bumper just pull out at the sides or do you need to undo any fasteners.
Bri
There is a plastic trim clip behind the wheel arch lining. Let me just get a link to a thread that covers this with photos
That's great info Ed, just what I needed to see.
thanks very much.
The H7s seem to make I big difference
Apologies that this is an old post but this seemed to be the best place to post...
Does anyone know where to get a trim clip that keeps the wheel arch lining in place pls? I don’t mean the clip behind it, the one that goes actually in the lining where you undo the 3 x T20 screws when you take off the bumper. Broke mine today. Oooops
have you tried VW parts some of the spares are very cheap, not everything from them you need to donate a kidney for
and they might hold them in stock
They're the same as the clips that hold the top of the grille. My local VW dealer had some in stock when I broke one.
I’m not sure they are the same as the ones that hold the grill, I seem to remember them being beefier than those ones.
I had the same issue and I think I’m still running with one clip missing
Thanks all. I’ll give VW parts a shout I reckon. I don’t think they’re the same from the top of the grill....they look different to me. I’ll pull one off though and see if it fits .
First DIY job I’ve ever done and surprised myself I only messed up this bit. The nice new Transporter HQ V3 DRL headlights were definitely worth it.
Same here, definitely different. I broke one as well, but doesn't seem to matter. But then, I measure my arch gap in feet, not mm :think smile bounce:
You're right. I checked mine. Same style of clip but definitely thicker. Not sure if you've seen this but it's handy for looking up part numbers.... VW SUPPLY
Sorry @benjemison , my friend is a vw specialist with his own garage and that was where we done the Led retrofit. He deals with Tps for parts virtually every day so he just phoned up and explained what he wanted and they delivered them. I could probably get you a part number on Monday when he is back at work if you have not got sorted by then. Just let me know
Anything you can get would be helpful
The clip is a piece of junk, spent more time faffing with the clips than anything else. Have left the clips off for the time being, but would like to put them back in ideally
