Recessed fridge in wall
Cripes... how do people have a fridge in a cupboard then...
I have through devious methods enquired with a converter and they apparently use the below in some instances. A depth of 400mm
Slimline 12v Compressor Fridge - 35 litre camping fridge ReVace RV35 12v 37 Litre Compressor Fridge - Slimline Fridge Silver or Black
Here’s mine.
I actually tried to fit it further back so it was flush as I’ve plenty room behind it but the door wouldn’t open.
This is as far back as I can get it
I think you will have the same issue with that fridge also.
It looks like it opens the same way as the THQ.
It’s not the depths you need to worry about it’s the width of the opening.
If it’s tight to the fridge either side I doubt you will get one to sit flush because of the way they open.
I have a top loader. I run it as a freezer and decant to a cool box. The lid limits overhead locker size. Also needs to be fitted before either back panel fitted or unit pulled into wall.
It's a lot more efficient than a front loader as the cold stays in when open the door
Pics ( not fitted lid to door yet this time round)
@Badjamin who made the cupboards? Can you not find out which fridge they intended to be fitted in the cupboard if that is what it was designed to contain?
Great advantage of the THQ fridge is the ability to totally remove the front in one easy go. Especially useful when there was a dog blocking the way.
This feature is most appealing. As mentioned earlier the possibility a fridge orientated in my cupboard may not likely open much past 90deg would hamper shelf/drawer/freezer compartment removal. A totall detachable door woyld aid that potential issue.
I decided to not go with THQ fridge. The opening both ways and fully removable action is cool but wouldn't have worked for my set up - the fridge needs to be inset into the cupboard flush to the threshold to allow the cupboard door to close and latch with room on both left and right sides (for the THQ fridge) and I only have a gap available on one side, so the fridge door would only open one way anyway as only one side would have a gap for the heel.. THQ were helpful to a point but when I drilled into all the elements of my issue I got the impression they were getting frustrated as their technician dismissed the issue and said there fridge will fit fine, it'll open fine despite the limited gap and the flush fit will be fine, that bar at the back wouldn't be an issue... I didn't believe them and didn't want to order another fridge and have to return that one as well. They even said they'd never seen a setup like this one before... I have seen it on Dan Chambers channel but not in any detail and he's gone quiet now (poor lad)
So,
I have pushed the button on this 400mm depth fridge. Can't find any reviews but a fair few outlets sell them so fingers crossed.
A shorter depth obviously means lots of room at the rear to have ventilation (I'll drill out vents in the cupboard both top and bottom to aid the flow). This will also allow me to reinstate the wall panel behind the cupboard and all the fluff insulation as well (glad I didn't cut out for the fridge back to slot in yet).
The width of the fridge vs the width of the cupboard means I will have a 20mm gap on the hinge side for the heel of the door to swing into.
To open it past this angle to aid shelf removal etc, I had thought I could take the cupboard door off as it has quick release style hinges that will allow a further 10/20 deg but these will be inaccessible obviously - it wouldn't stop me unscrewing the door from the hinges. Will know for definite if this speculation has any merit when the fridge is in. If I am mistaken and the fridge door won't allow me to remove the freezer compartment then... well it's 4 screws holding the fridge in, I can always pop them out and shufty the unit out a little ways to allow increased door opening and freezer removal if I ever choose to remove it.
As far as flush fit cupboard units go, I would advise against self converters going down this route, I did not want to cut out the side impact bar at all and I am 100% positive that a fridge with a true depth of 500mm would absolutely not have fit into a recess hampered by a 40mm metal protrusion.
Thanks be to all of you for advice and warnings of door protrusion issues and the like.
I'll send photos and post a little vid at some point to show how amazingly simple I found this whole process... guffaw!
Have you thought about a top loading fridge? We have one in the new van and I love it. Never an issue with access no matter whether bed is set up or where seats are. You’d think it would be harder to fit stuff in but I think a lot of space gets wasted in a normal front loading fridge. Fridge is behind the panel next to the drawers in the pic, with a lift up part of the worktop to access it.
Where did you get the units from? They look really good.
Mine was fitted by knights the conversion company but you can get them here
Mine is the TL20 but they fit the larger one with rhe 112 bed. I decided I wanted a bigger bed and straight units and will chuck a portable fridge in if I need more.
