Hi everyone i had my van mot done yesterday ( 2015 t32 sportline 53000 miles) passed ok but tester gave advisory for slight play in rear wheel bearings. Has anyone had this job done and could i ask much did it cost .
Hi I am thinking of doing it myself with FAG high quality bearings but I would need to get a puller kit ( £38 from ebay) which I could then keep if I need to do the front in the future .I did it myself. Well front anyway. Not a bad job tbh. And deffo front harder than the rear.
I'll be doing the sameHi I am thinking of doing it myself with FAG high quality bearings but I would need to get a puller kit ( £38 from ebay) which I could then keep if I need to do the front in the future .
Hi I found a new kit on ebay for £38 probably not professional quality but ok for DIY.The DIY kit is about £40 so you could do the bearings and sell the kit on.
Hi DaveD I could do that but I'm concerned that if I don't get it done as an advisory it will be a fail next year and I will have to do it anyway.
Hi Dave I would usually agree with you but the place I have used for 8 years are called Mot test and that's all they do they do not have a work shop and do not do repairs . In 8 years they have failed my van twice once for the the reflectors on the TL-RS rear bumper did not actually reflect and once because the letters on a set of new number plates were not correctly spaced they also aligned a set of aftermarket led headlights i fitted free of charge .Not necessarily, It is a bit subjective and I believe that some testers (not all) dish out an advisory if they think that you'll then book it in with their garage to have the work carried out.
I once had an advisory for front lower arms 3 years running, they have voids in the rubber bushes and even from new they appear to have a bit of play in them.
It'd be unusual for the rear wheel bearings to start to fail in a van of such low mileage.
There’s still no harm in jacking up yourself and checking, 10 min work. You’ll also have a reference to compare with after the repair.Hi Dave I would usually agree with you but the place I have used for 8 years are called Mot test and that's all they do they do not have a work shop and do not do repairs . In 8 years they have failed my van twice once for the the reflectors on the TL-RS rear bumper did not actually reflect and once because the letters on a set of new number plates were not correctly spaced they also aligned a set of aftermarket led headlights i fitted free of charge .
Btw if you take your vehicle for a retest in 14 days it's free what more could you ask .
Yes it does sit around a bit sometimes hence 53k miles in 11 years.There’s still no harm in jacking up yourself and checking, 10 min work. You’ll also have a reference to compare with after the repair.
Very odd that the bearing is failing at such low mileage, has the van spent long periods without moving?
Static roller, needle and ball bearings deteriorate badly if left in the same position under load.
Even if you rotate the wheels 1/4 turn and start the engine it will help if it’s not being used.Yes it does sit around a bit sometimes hence 53k miles in 11 years.
Brinelling?There’s still no harm in jacking up yourself and checking, 10 min work. You’ll also have a reference to compare with after the repair.
Yes, everything is vibrating 24 hours / day.Brinelling?
