Anyone know what the 2 holes for the rear numberplate use to secure a numberplate ? Screw, bolt, magic.....?
Stainless steel...the best peace of mindAnyone know what the 2 holes for the rear numberplate use to secure a numberplate ? Screw, bolt, magic.....?
You mean vertical!Plastic ones for me too, but from memory I needed to trim a fraction off the length. Make sure the slots in the heads are level tho'.
Controversial!You mean vertical!
horizontalYou mean vertical!
It doesnt apply to plastic, but I was taught vertical to allow water to run out and thus reduce corrosion.horizontal
I was joking I'm old enough to remember slotted wood screws all being in the same directionIt doesnt apply to plastic, but I was taught vertical to allow water to run out and thus reduce corrosion.
Mine have caps on the screws so my screw orientation is hidden is it a MOT failiure if this is wrong, plus one screw cap is blue old EU style plate should I get new platesIf it's a black screw in a digit, the slot has to follow the orientation of the line of the digit it goes through. That obviously dictates the orientation of the other screw.
If they are both yellow, then horizontal to match the portrait orientation of the numberplate.
I am generally the same until the weather gets too hot and the glue meltsdouble sided tape here, much tidier![]()
