Is anyone able to offer advice/ opinions on whether my rear main seal needs replacement? (T6 CAAC engine, 6 speed box, mileage 75k) And if I need to replace it, do I need to drop the sump and use the special tool T10134 or is there a work around? I have just dropped the box and removed the clutch and dual mass flywheel and found oil around the seal (see attached) but I can't work out whether the oil is coming from the bolt holes or from the seal. I included a picture of the back of the dual mass flywheel where it appears to have a fine oil misting. There doesn't appear to be any leakage at the 6 o'clock position directly below the seal so that's what's confusing me.
Reason for doing the clutch was because the slave cylinder bearing (CSC) started failing. The clutch was also getting juddery so I assumed brake fluid had got in the clutch. However, it now seems it may be oil and not brake fluid.
Any advice and shared experience appreciated.
