callikev27
Hi there, I recently joined the forum in the hope I'd be able for solve a bit of a head scratcher that I’m having trouble figuring out. It may be something simple I’m missing but I’m struggling at the moment and I've yet to find a post with a similar fault. Hoping that there's an electrical genius on here who could help.
So, I have a California with an electric sliding door that's not working but there is some background to this story - I’ve just come back from a trip to Wales. On the trip I crossed a ford to get a campsite one night, it was pretty shallow and I had no dramas crossing. The following morning I crossed again with no dramas but later noticed the charging system for the camper electrics wasn’t registering any current going in when driving. With some online research I managed to locate the 80amp fuse under the seat which had blown. Replacing it made no difference so bit more digging found that this was supplied from a fuse under the battery. Sure enough the 100amp fuse under the battery had also blown. I replaced this and all was good in the world! Everything was working and charging as it should be until I noticed the electric sliding door wasn’t working!
The door no longer works from the key fob or internal buttons and the internal buttons no longer light up either. I've had a chance to look at problem a little more now I'm home and these are my findings so far..... Research shows it might have be the controller but after stripping the rear panel off to look it at it appears all good. I checked the voltage to the controller and it’s 1.5v! It should be battery voltage. I then checked the 40A fuse that powers the sliding door (all good) located under the seat and it’s the same there only 1.5v and its the same if the vehicle is running or not. My understanding is this is fed off the 100amp fuse 3 under the battery which I know is good as all the split charge system, which runs off the same fuse, is working fine so my question to any gurus out there is why don’t I have a battery voltage to the 40amp fuse under the passenger seat? Is there’s something in between the two I’m missing?
Just to prove my theory I connected a 12v battery directly to the 40amp fuse feed for the door and the door worked fine so it’s 100% a supply voltage issue but for the life of me I can’t work it out.
Any help on this issue would be greatly received as it’s driving me up the wall
Just to note it’s a 2011 California SE (posted here as all sliding doors seem to be wired the same) and up until a few days ago had been faultless.
Kev
Kev
