possible clutch switch failure
ronney
hi all.
I have a problem with my van. t6 tsi 19 plate. it will not start. I press the clutch in and is still says depress clutch. I'm assuming it's a faulty switch. does anyone know if there is a fuse for this or what voltages should be going through what wire as I have red green yellow and black wires going to the switch. tia
hi all.
I can’t be sure if the T6 is exactly the same, the two images below are taken from a VW manual
thanks for that.
mines different to that. I've managed to get a multimeter onto the wires. I'm getting 12v on the red green and yellow. 0v on the black but when the pedal is depressed I'm getting 12v on the black but 0v on the green yellow and black. wasn't expecting it to change tbh so now not sure it's the sensor. looks like I need to get it plugged in somewhere
