Try clear sail repair tape if you need a temp fix. Sometimes it's also called Heli tape. It's like thick version of very sticky clear cellotape. Cut a square peice to cover the damage and then cut round cures at the corners of the square. Stick your new patch on over the hole. Use two prices. Onc on the inside and the outside. Not elegant, but a quick repair to keep you water tight.
