Park Pilot And Led Drl's
Morrispd
I've got park pilot on the rear and wanted to add to the front, I see there is a kit in the shop but what if you want to add the LED DRL upgrade too? Is the trim just drilled for the sensors or is it a different trim part?
Also is the rear park camera upgrade fully compatible with park pilot sensors / display? Is it a completely independant system
Front sensors, camera and DRLs are all completely independent of each other interms of wiring and functionality
The front parking kit comes with replacement trims that have sensor holes cut and sensors and mounts in situ already stuck to the rear of the panel (same as if factory fitted)
The genuine VW DRL kit also comes with replacement front panels that house the DRL unit and this panel is unique to the DRL kit and only available with the kit but unfortunately VW do not make/supply the DRL kit with sensor cutouts so if you want both you have to use the DRL panels and cut the sensor holes into them and then transfer the sensor and mount from the other trim panel that came with the front sensor kit
The DRL kit and front sensor kit are straight plug and play but the rear view camera kit needs to be coded in after installing using VCDS/VagCom
Yes mate just need to sort a date to catch up, im not going to be able to make the 2nd or 3rd as discussed as im working that weekend so need to find another date, lets take this back to PM and we can sort a date that works for both of us
