Hi
2019 transporter 150hp diesel dsg
I get the eml light when starting the engine after it has been sitting for some while. Normally it will not light if it's just a short stop.
I read the fault code P0237 via VCDS.
I have tried replacing both map and maf sensor. Also tried wiggeling(?) the wires when engine running and intake air pressure open in advanced measuring values without seeing anything wrong.
Also changed the battery as it was the original since the car was new.
But i still get the eml and faulty start/stop. Engine cooling fan also running high even if engine is not hot after stopping.
Does anybody have any tips or tricks I can try?
When clearing the code after startup, it never shows again until next time I start the engine.
Start/stop does not work tough.
