Override Door Timer
James1000
I have an led strip fitted above sliding door - which is excellent as a door light but I would like to override it to use when parked up.
I’m assuming it still runs of the vehicle battery and is s direct replacement not part of the ‘leisure ‘ set up
I'd say so if it come on and off with the standard rear lights.
You could increase the shut off time via VCDS... (if you have factory LEDS VW increase the lights timer from 10min to 60min)
Or you could run a separate feed wire to the lights via a switch.
