Ovano & Reimo
Mrshabbs
Hi All
Does anyone have an Ovano Switch XL and a Reimo pop-top combination installed? I am considering the Ovano however I am unsure if the bulkhead will be too high with the Reimo pop-top installed. I am assuming the Reimo will reduce the interior height of the van slightly and therefore prevent the Ovano bulkhead raising to its upright position? Does anyone have this issue? Thanks
Hiya.
I have an Ovano Switch XL but no pop top.
If you need any measurements for anything let me know.
Maybe someone on here has just the pop top so together we can help.
Hi All
I like that you have asked this, I would be doing the same to mine with a reimo pop top
Hiya.
That would be helpful, thanks for the offer. I have asked my converter for the dimensions between the kombi floor (with factory rubber load mat) to the underside of the Reimo bed. Are you able to provide the measurement from the underside of the Ovano (van floor) to the top of the Ovano when in the upright position? Thanks!
I have just found this on the Ovano site:
Height from floor – 580mm
For a standard van with no modifications the height from the top of the flatbed to the ceiling of the van is 790mm
that should mean a 1370mm clearance is needed.
Morning. From floor to top of Ovano is 575mm.
I have a rubber floor in mine.
I believe she is after the "bulk head up" dimension because she is afraid that his new ceiling level is too low.
Gotcha. Thought She wanted it Folded as in ready for bed.
I did wonder as she had the measurements already.
@Mrshabbs I’ll get the measurements over once I’ve unloaded the ladders out the back.
Thanks very much @BuilderJay. I/Me/He need the measurements to the top of the bed when upright, as in the above image, if you could please. Many thanks.
I can confirm you'll be ok with ANY pop-top, even with the low profiles ones that drop the ceiling height. If you have any further questions please do contact us directly (details in signature) as we're always happy to help.
@Josh (OVANO)
Got more stuff over here.....
