[Fuel line] Leak on to gearbox
Looks like gearbox? Could you clean it all off and see exactly where it’s leaking from. Is the van in warranty?
2016 reg so out of warranty, will clean off and have a look, not much of a mechanic but wanted a better idea before talking to garage / dealer.
Difficult to tell without comparing to another gearbox, but the drain plug seems to stick out a lot. Is the oil clean, or black? If it’s clean, it’s not likely to be engine oil from a diesel, but likely gearbox fluid.
DSG or manual? If the gearbox fluid has been changed, it may be a factor. Can you check the fluid level on the ‘box?
