2018 204 DSG LWB PV. 15K miles. Van has run more or less faultlessly. For last couple of weeks there's been an only just noticeable power steering whine, as if the fluid was low. It wasn't. On last couple of motorway trips the van felt very floaty and a bit unstable. I though that it was tyre pressures. Tonight on way home, traction control and ACC fault lights come on, and steering wheel moves above 30 degrees to the left. No knocks, whines, rattles or vibration. I stopped straight away, nothing loose or dripping. A couple of restarts and lights still on.
When I say moved 30 degrees to the left, it's now offset 30 degrees. It used to be straight on dead ahead, now it's counterclockwise by about 30 degrees.
When home, I jacked the thing up, again nothing loose, my adjustable TCA bushes still tight and not moved. No cables off, hanging or loose.
VCDS went mad. Multiple Steering angle sensor Signal Implausible errors, but all in the ABS module. Steering angle itself says no errors. Steering is stiff on full right lock, smooth the rest of the way.
Where's the steering angle sensor ? In the rack ? I can only thing that the rotary or spool valve in the rack has gone faulty, or some bush in the rack has broken up, but for the steering wheel to now be 30 degrees offset is some movement. Power assistance is largely unaffected.
I have definitely not hit anything or curbed it.
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 63317000000836
Coding: 557E40986562847EAA7B027AA68621D379F100
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3F87BA46A65CEEB79E-806A
3 Faults Found:
0289 - Steering angle sensor
B1168 29 [008] - Signal Implausible
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 24808 km
Date: 2019.11.18
Time: 20:04:13
0293 - Steering angle sensor
B1168 29 [137] - Signal Implausible
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 206
Mileage: 24816 km
0301 - Steering angle sensor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 24808 km
Date: 2019.11.18
Time: 20:00:37
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 26111713470402
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF90742E1D627BFD5-802A
No fault code found.
See how odd. No faults in Steering angle sensor, but three in the ABS module that occurred when the fault happened. As it's stiff on full lock, something has happened with the rack.
Has anyone seen anything similar ?
The local stealer is trying to sell me a new Toerag. I'll drop it in next Monday when I get a Toerag on an extended 48 test drive...
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake function status-ABS intervention: No
Drivetrain coordinator: brake function status-ESP intervention: No
Drivetrain coordinator: brake function status-EDL intervention: No
Drivetrain coordinator: brake function status-ASR intervention: No
Drivetrain coordinator: brake function status-MSR intervention: No
Drivetrain coordinator: brake function status-Driver braking: No
Drivetrain coordinator: brake function status-HDC active: No
Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
Drivetrain coordinator: brake function status-EPB active: No
Drivetrain coordinator: brake function status-ASP intervention: No
Drivetrain coordinator: brake function status-ADS intervention: No
Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
Drivetrain coordinator: brake function status-ACC stopping distance control active: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 24808 km
Date: 2019.11.18
Time: 20:04:13
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 206
Mileage: 24816 km
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 24808 km
Date: 2019.11.18
Time: 20:00:37
Coding: 01
