Hi
I picked up my 17 reg' T6 California Camper from the VW workshop today having asked them to look at several issues including the soft close sliding door. The door has been developing an intermittent rasping/creaking noise when I initially open it (i.e. as it de-latches) which has now become permanent. The door otherwise operates just fine opening and closing. The noise is so loud that it attracts attention and makes me extremely unpopular on campsites, especially at night. I've discovered that I can largely avoid the noise if I de-latch the door by pressing the lock in with my thumb whilst pressing the door firmly closed with the rest of my hand (or leaning my body against it).
Sadly, VW are wanting a minimum of £600+vat to fix the issue since they claim that they'll need to fully remove the door to gain access to the soft close mechanism. I'm not convinced and suspect the issue is more to do with adjustment or lubrication given that the door otherwise operates perfectly.
I've been trying to isolate the source of the noise myself and it seems to be coming from or near the striker plate of the soft close mechanism - see 1:30 of
Has anyone else experienced this problem or does anyone have an idea what might be causing it? My initial thoughts are that the striker plate mechanism may need adjusting -I've tried greasing it without much luck. In order to adjust it, I'll need to loosen off the screws holding it in place but I'm not sure what tool I need for the screw heads. They look a little like torqs, but seem to have more grooves - some sort of star. Anyone know the name for this type of screw head? Loosening off the striker plate might also let me inject some grease into the actuator mechanism behind the rotating cam on the striker plate which might also be the source of the noise.
Many thanks for any suggestions
Des
Des
