Have a 2017 VW T6 204PS Bi Turbo CXEB engine(Old Turbo no.03N145703G) ordered a new turbo but the old Oil feed sensor heat shield doesnt fit as the manifold has changed on the new one is shorter.
Cant find a replacement part from VW, has anyone else had this when replacing turbos?
the engine bay from up topo looks basicaly the same, as the Long Block engine has all of your bolt on ancilleries swapped from the old engine to the new.
so all this is from before.
but from underneith it looks a lot shineyer . . .
checking the oil - its so clean you can even see the level. . .
a closer look through the window in the bell housing shows the new DMF too . . .
further back we see the berand new DPF and CAT . . .
