Passenger side indicator not working all the others do just that one are the indicators on separate fuses each side ? . I've changed it to a new bulb but still no good any ideas thanks .
Yes, check the terminals on the light fitting has the 12v on/off.
If not then you need to follow the wires back to the next connector and check there.
If you fitting an LED lamp try turning it round so the pins are swapped over when you push it back in.
Hi, iv recently inherited these faults, was hoping someone may be able to help,
Checked fuses in car and in front of battery tray and all seem good. Bulbs all work because if reset faults with vcds all work fine for little wile. Nearside front and rear don’t work with fault.
