k
Second from bottom picture?
That's a daily side project!
I wish vw were as quick as you
Yes, apparently I took too long insulating the van so he got his own tea.Is your cat snacking on a mouse?!
@Steve1978 Sorry to mention it after you getting so far on but it would be worth putting in some front to back cable ducting (with a draw cord/wire inside) in case you want or need to add other electrics later such as dashcam with rear camera. If you do this and you then use the cord to draw cable through, don't forget to draw a replacement cord with the wire
Corrugated tubing with any bends being radiused curves especially if you will be pulling cable with prefitted connectors. What camera are you going for?Yeah that's a good shout. I have a camera on its way was just going to route it with the lighting but defo worth looking at a wire channel of some description
