Decided to build my own sliding tray to carry 3 MTB's in the back of my SWB Kombi, as didn't want to fork out £700-900+ for the ones sold online.
Mine is made up from 18mm hardwood ply and a mixture of fixings from B&Q and Toolstation approx £60. Heavy duty 1400mm lockable Vadania sliders (250kg rated not that I'll need that) from Amazon £160.
I already had the bike fork mount rail from Blok Pod, so wanted to use that as part of the tray. I wanted to built the tray so that it can be removed quickly if needed, it does need two people to remove as it is quite heavy once together.
Here are some pics for anyone interested.
Made two support bases from scrap ply, which fix down to the lashing points on my kombi with M10 handles (front will be replaced with bolts to allow tray to slide)
Then bolted these Heavy Duty Angle 90 x 90 x 40mm wide / 3mm thick brackets from Toolstation to the sliders
Built the tray using 18mm hard wood and 70mm batten for the sides and fixed the sliders to the tray. Also measured up the fork mount rail which sits on the end in front of the side batten.
Next job was to fit the tray to the base. I didn't want to drill any holes in the van ( I didn't trust myself TBH)
So my only option was to use 15mm screws and lots of them through the tiny bracket holes. I wasn't sure if they would be enough to support the weight, but it does... for now at least
Kept the Rhino boot liner in to stop the van being caked in mud from the bikes and everything else.
Painted the tray over the weekend in MSP, all I'm waiting on is the rubber flooring and some aluminium edges to tidy up the tray.
I may need to strengthen the base as some point. I only needed it to support around 130kgs of Ebikes and kit. So should do the job.
I will add lashing rails to secure the front wheels and may even make a stand for the bike jet washer.
