2015 T6 Highline. Was driving along a couple of days ago when multiple warning lights came on simultaneously.
TPMS light was flashing with a message on the screen saying something like TPMS currently unavailable. ESC and ABS lights solidly on.
Also saw a message on the screen saying auto stop/start was unavailable, and indeed I came to a stop somewhere safe and put it into neutral and it didn't stop. Had a quick look around it, couldn't see anything obviously wrong.
After a few minutes, all the lights disappeared and everything went back to normal. It did it again about ten minutes later on the same journey.
I gather this is most likely one or more wheel speed sensors? Would that also affect the auto stop/start?
I parked up overnight and it did the same when I started it for the first time yesterday morning, again sorted itself out after a couple of minutes. Drove a few hundred miles home in the afternoon and it was fine the whole way
Will I see anything if I put my basic OBD reader on it? I'm guessing not because the check engine light isn't illuminated indicating there's a stored error code to look at. Presumably I'd need something a bit more advanced that can actually interrogate modules rather than just seeing pending/stored codes in the ECU?
