JonatanMol
Hi all,
I have a 2020 T6.1 BiTDI 199 hp and I’m looking for some advice.
I was in the mountains here in Sweden last week with temperatures between -10°C and -30°C. There were a few cold starts, but most of the time the van was standing still and we only did short drives. The diesel heater was also used. When we were about to drive home, the yellow check engine light and the EPC light came on, and the ACC stopped working. The van feels sluggish and does not accelerate as usual, but we were still able to drive home.
Possible clues at the time:
Since then I have done the following:
Current status:
Additional info:
Any input is appreciated.
Cheers!
- We usually run a cooler plugged into the 12V socket during long trips. Before leaving and plugging it in, I got an error message on the cooler related to a voltage issue (never happened before).
- When trying to activate ACC, I got the message: “Turn on main power switch.”
- Replaced the original 2020 battery with a new AGM battery
- Coded the new battery to the vehicle
- Cleared all fault codes
Current status:
- Only remaining fault code: P246300 – DPF soot accumulation too high
- EPC light still on
- No other active engine fault codes
Additional info:
- After disconnecting the battery on the way home from the mounatins, the DPF warning lamp came on briefly, but disappeared again after a longer drive.
- Can high soot load in the DPF trigger EPC even if the DPF warning lamp is not currently on?
- What would you recommend as the next diagnostic step?
- Are there specific live values I should check (differential pressure, exhaust temperature, soot load, etc.)?
Cheers!
