Multiple Retrofits, Side Assist, Trailer Assist and Park Assist - VCDS help required please
DubHaus
Indium Grey T6.1 T32 Highline Kombi - WIP
VCDS User
Hi All, retrofits coming on nicely, but I do have a number of errors in various modules. Probably didn't help in retrofitting multiple options in one go, however..... If anyone can help and sanity check my module coding it'd be greatly appreciated.
09 Module error - I've got the window down a touch for an extension lead into the Van
10 Park Assist, 3 errors I need help with please
17 Instruments, 2 fault codes I need help with please
29 & 39 no idea what these are as they're not ticked in the CAN Gateway installation list
5F Ignore - speaker faults
65 TPMS, ignore error as I need a parameter file uploaded
75 Telematics, ignore, I've got the roof LTE module unplugged
Code:
Tuesday,23,April,2024,16:52:23:60815
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZNH006670   License Plate: DU68AUS
Mileage: 37530km-23320mi   Repair Order: 23042024
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 29 39 3C 44 55 5F 65 69 6C 75 D6
          D7
VIN: WV1ZZZ7HZNH006670   Mileage: 37530km-23320miles
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DNAA)       Labels: None
   Part No SW: 05L 906 023 JG    HW: 05L 907 309 F
   Component: R4 2.0l TDI   H80 2670
   Revision: N1H80---    CVN: F19C03D9F3218A0EA3C795CF64CF85E9A3C795CF43FB2DAA
   Coding: 001900340344050800000000000000000000000000000000
   Shop #: WSC 09107 004 1048576
   ASAM Dataset: EV_ECM20TDI01105L906023JG 006002
   ROD: EV_ECM20TDI01105L906023JG.rod
   VCID: 76B5E8CC5849E54A05F-8022
   VINID: 9E606AAAA1D8A9E600006187007D68BD3B
No fault code found.
Readiness: 0 0 0 1 1
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7LB 614 517 B    HW: 7LB 614 517
   Component: ESC_base      H01 0800
   Serial number: 08501132210616
   Coding: 10552752C847E68B085AE4AB13666726393324B8
   Shop #: WSC 00012 790 00028
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
   ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
   VCID: 3FDB4DE837F36402169-806A
Address 08: Auto HVAC (J301)       Labels:* Redir Fail!
   Part No SW: 7LA 907 426 E    HW: 7LA 907 426 E
   Component: AC Manuell    H01 0602
   Coding: B03110000810030001000800504001050000000000011000800000000000
   ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
   ROD: EV_AirCondiBHTCVN54XT6PA.rod
   VCID: 45D75F00552F3ED25C5-8010
   Rear air conditioning block 1:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 2Q0 937 090 D    HW: 2Q0 937 090 C
   Component: BCM A0 Std+   H12 0954
   Serial number: 01102117601614 Dataset Number: V03935350KN 0001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_BCMA0 207001
   ROD: EV_BCMA0_207_SK26.rod
   VCID: 333311D80BBBB062E21-8066
   Rain/Light Recognition Sensor:
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: S5Y21M06D10H18M01S31
   Coding: 0218EE
   Driver door control module:
   Subsystem 2 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000051439750
   Coding: 1F0007
   Front passenger door control module:
   Subsystem 3 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000051408103
   Coding: 050007
   Anti-theft alarm system sensor:
   Subsystem 4 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL21138CMUD
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000049677542
1 Fault Found:
590853 - Window Regulator; Front Drivers Side
          B14D1 54 [00001001] - Missing Calibration / Basic Setting
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:37
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0  C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.6 V
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0073
   Serial number: 000150057322038 Dataset Number: V03935360WN 0001
   Coding: 8B71567941
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_010_AU37.rod
   VCID: 58E98674B29DB33A373-800C
3 Faults Found:
12658704 - Databus
          U1121 00 [00001001] - Missing Message
          [Steuerger t f r elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:37
12664896 - Databus
          [Bildverarbeitung - ARA_Sensor_02 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:38
12727554 - Databus
          [Steuerger t f r Heading-Control - Gateway_79.LDW_02_alt - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:39
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Dataset Number: V03935335RG 0001
   Coding: 2A04601B01FF8748949C815560509700000000000000000004
   Shop #: WSC 00012 790 00160
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 43D341185B1B00E2721-8016
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
   Component: VW22Airbag    016 0506
   Revision: --------    Dataset Number: V03935338FP 0001
   Coding: 8800C000000000007C0000CF008C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 7F5B0DE87773A402569-802A
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7LA 920 941 A    HW: 7LA 920 941 A
   Component: KOMBI         202 8500
   Coding: 27A50A822488260001882A2D6401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 3E2530EC30F96D0A1DF-806A
2 Faults Found:
13636608 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:36
16776996 - Databus
          [FCW_01 keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:36
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 08062110802964 Dataset Number: V03935338SA 0001
   Coding: 030100044F056A0000000058000F00010001070000000000000000000000
   GVL: 014C3C0000000000C04090008002480000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW27.rod
   VCID: 79AFE3F069578A3268D-802C
   Generator:
   Component: 5-00-11-00-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3G0 959 442 N    HW: 3G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440036155215438
   Coding: 2C0D00
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 77343301002105250133
Address 29: Left Light
Cannot be reached
Address 39: Right Light
Cannot be reached
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 00000563861325  Dataset Number: V03935334PN 0001
   Coding: A2A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392F23F029D74A3228D-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 00000564886889
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 G    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7160
   Dataset Number: V03935340DA 0001
   Coding: 0306
   ASAM Dataset: EV_SteerAssisMNB 002015
   ROD: EV_SteerAssisMNB.rod
   VCID: 46D5580C682935CA55F-8012
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0080
   Revision: --------    Serial number: --------------
   Coding: 0C8A020009200001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: EV_HeadlRegulAFSMQBMAX_VN46.rod
   VCID: 41DF4B10410712F260D-8014
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 3CN 035 869 A    HW: 3CN 035 869 A
   Component: MU-E-D-ER     720 0920
   Serial number: 18052100021852 Dataset Number: V03935343RV 0001
   Coding: 06570000AA00000041111101008002001F0000C60000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VW27.rod
   VCID: 44D142045E1507DA4BB-8010
4 Faults Found:
0512 - Rear Right Bass Speaker
          B1067 13 [00001001] - Open Circuit
          [Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:38
                    Voltage terminal 30: 12.5 V
0517 - Front Right Bass Speaker
          B1062 13 [00001001] - Open Circuit
          [Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:38
0522 - Front Left Bass Speaker
          B105F 13 [00001001] - Open Circuit
          [Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:38
0527 - Rear Left Bass Speaker
          B1065 13 [00001001] - Open Circuit
          [Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:38
Address 65: Tire Pressure (J502)       Labels: 3AA-907-273.clb
   Part No SW: 5Q0 907 273 D    HW: 5Q0 907 273
   Component: RDKBERU30     H06 0010
   Serial number: 30000000707352
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_VW41.rod
   VCID: 363528CC18C9A54AC5F-8062
1 Fault Found:
12652550 - invalid data record
          B2005 00 [00001001] - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:45:05
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H0 907 383 C    HW: 5H0 907 383
   Component: Anhaenger     H12 0058
   Serial number: 000000000006247
   Coding: 0100000202001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001012
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 2E0500ACE0999D8A8DF-807A
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: 81A909460E  0001
   Coding: 0123010103002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0092
   Serial number: 0000000105NVTD1 Dataset Number: V03935344U  0001
   Coding: 06462000196818208005460160000607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VW27.rod
   VCID: 015F8B100187D2F220D-8054
1 Fault Found:
1572115 - LTE Antenna 1
          B17FD 13 [00001001] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 37530 km
                    Date: 2024.04.23
                    Time: 16:44:39
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 619FAB90E1C772F240D-8034
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H08 9002
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----------(Elapsed Time: 01:40, VBatt start/end: 12.2V/12.5V)-----------
As always, any and all help greatly appreciated
The original/factory Auto-Scan before any modifications would certainly be helpful.
Pre retrofit scan
Code:
Sunday,12,November,2023,10:38:01:60815
www.Ross-Tech.com
Mileage: 36908km-22933mi   Repair Order:
Scan: 01 03 08 09 10 13 15 17 19 29 39 44 55 5F 6C 75 D6 D7
VIN: WV1ZZZ7HZNH006670   Mileage: 36908km-22933miles
10-Park/Steer Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
75-Telematics -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
   Coding: 0018EE
   Coding: 1F0007
   Coding: 050007
   Alarm horn:
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058321162 Dataset Number: V03935313KK 0001
   Coding: 8451151801
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_010_AU37.rod
   VCID: 53F37158AB7B9062C21-8006
   Coding: 2A00600201FF8748949C815560509700000000000000000004
   Coding: 27A50A022580260001882A010401000000000000
   GVL: 01443C000000000040009000800248000000C000000000000000000000000000
   Generator:
   Coding: 2C0D00
2 Faults Found:
131734 - No Communications with Undefined Control Module
          U1126 00 [00001001] - -
          [Timeout Knoten 0x96]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 36908 km
                    Date: 2023.11.12
                    Time: 10:34:29
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
131735 - No Communications with Undefined Control Module
          [Timeout Knoten 0x97]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 36908 km
                    Date: 2023.11.12
                    Time: 10:34:29
                    Terminal 15: On
Cannot be reached
Cannot be reached
   Coding: 0106
   Coding: 0C88020009200001
   Coding: 066401003C00000041110101008000001F0000C60000010000
   Coding: 0123010102002017000040
End----(Elapsed Time: 01:29, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
Address 19,3Q0 907 530 AL,recoded (Installation List),from,01443C000000000040009000800248000000C0,to,01443C000000000040009000800248000000C0,,
Address 19,3Q0 907 530 AL,recoded (Installation List),from,01443C000000000040009000800248000000C0,to,01443C00000000004000900080024800000000,,Sunday,12,November,2023,10:57:46:60815
www.Ross-Tech.com
   Coding: 0018EE
   Coding: 1F0007
   Coding: 050007
   Alarm horn:
   Coding: 8451151801
   GVL: 01443C0000000000400090008002480000000000000000000000000000000000
   Generator:
   Coding: 2C0D00
6 Faults Found:
131714 - No Communications with Undefined Control Module
          U1126 00 [00001000] - -
          [Timeout Knoten 0x82]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 72
                    Mileage: 36908 km
                    Date: 2023.11.12
                    Time: 10:52:29
                    Terminal 30 power supply: 11.5 V
                    Terminal 15: On
131715 - No Communications with Undefined Control Module
          [Timeout Knoten 0x83]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 72
                    Mileage: 36908 km
                    Date: 2023.11.12
                    Time: 10:52:29
                    Terminal 15: On
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 72
                    Mileage: 36908 km
                    Date: 2023.11.12
                    Time: 10:34:29
                    Terminal 15: On
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 72
                    Mileage: 36908 km
                    Date: 2023.11.12
                    Time: 10:34:29
                    Terminal 15: On
131736 - No Communications with Undefined Control Module
          [Timeout Knoten 0x98]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 72
                    Mileage: 36908 km
                    Date: 2023.11.12
                    Time: 10:40:20
                    Terminal 30 power supply: 11.7 V
                    Terminal 15: On
131737 - No Communications with Undefined Control Module
          [Timeout Knoten 0x99]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 72
                    Mileage: 36908 km
                    Date: 2023.11.12
                    Time: 10:40:20
                    Terminal 15: On
Cannot be reached
Cannot be reached
   Coding: 0106
End----(Elapsed Time: 01:29, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
Thanks @mmi
It seems they were ticked at some point as also pre-retrofit scan have them - even gateway was trying to communicate with them?
Has OBDeleven possibly used on the van?
Maybe pre LED Headlight retrofit. I'll have to look for old laptop to see if I've still got logs.
Not sure if OBDeleven has been used, certainly not since I've had the van, although it could have been used by previous owner
Ok. Just asked because there are quite a few cases where Gateway Installation List has been somehow messed by OBDeleven.
Should get rid of those - somehow?? Perhaps try to tick them and save, and then untick and save again - yes, sounds a bit desperate...
I don't have any documentation on this one. The faults refer to a bit strange controllers so perhaps a coding isuue.
Below known good codings on T6.1 - the top one is yours - not exactly the same as any other.
If you want to experiment quickly the same as text strings to copy and paste into VCDS
8B71567941
8271167951
8A71167941
8A71561971
0271161871
8371167851
8379167951
8379161851
8A71167951
8371165851
Thanks @mmi
I've now tried the suggested codes and most then create new errors. From what I have been able to work out so far is that the first error is because the module came from a car with electronic parking brake, and the T6.1 doesn't have this.
The second error appears to relate to the rear view camera 6C incorrectly coded.
The third error may be to do with the ABS 03 module that I haven't been able to code for the trailer retrofit
I think I need to double check the coding needed for the Trailer Retrofit, which may be incorrect. I followed the coding as per >> HERE << and have no errors in the 69 Trailer Module?
OK, so Byte 0 Bit 3 relates to trailer assist and the second error. To enable Trailer Assist it looks like I need to correctly code other modules
Ah, trailer assist!
I haven't seen your AUTOSCAN but I guess you need to change your revesing camera to Compact+ version.
Example below.
The one on the right in the photo above has NO TRAILER ASSIST support.
The one on the left supports TRAILER ASSIST.
Thanks @Robert all coding and adaptions OK except module 6C, rejected Optical ARA error 32 out of range. would you be able to check my module 6c coding above please?
Aah....
The dataset in your controller per your scan is: V03935360WN 0001
The few T6.1 I have that information have: V03935331VA 0001
That possibly explains the fault about missing electronic parking brake.
Aah....
Is it possible to code EPB out in the module?
I don't know. I guess the correct dataset needs to be loaded into the module.
Does the system otherwise work correctly?
I'm not 100% sure, I've tried and it shows the message, park assist stopped take over steering. I'll take it for another test drive tomorrow and see what happens
Also, I tried adding 29 & 39 to installation list and then removing them but they're still there! I'll have to live with this one as it's not causing an issue
You need to replace your camera in order to be able to activate this functionality.
