Hello
Yesterday I bought an Opel (Vauxhall) Movano L2H2
I also want to insulate this one but do not want to work with Armaflex/K-flex anymore
I was very unhappy with Armaflex/K-flex with especially because it holds so much heat in the summer, even by evening it still felt warm
I am from Belgium so ordering from the UK is almost impossible, many companies do not ship to Belgium or there is a high cost for import/tax.
Against the cold I will use Ecopeg 39 (Pet insulation) I will not fill the cold bridges anymore with it.
As a first layer I want to do a Thermal liner of 10mm then as much as possible with Ecopeg 39 (35mm) the cold bridges I thought to cover with aluminum tape and against the wall/ceiling panels an extra layer of Self-adhesive Reflective Insulation Foil with Double Layer of bubble wrap to keep the sun heat out as much as possible, I finish the inside of the panels with 4 Way Super Stretch Lining Carpet
Link Self-adhesive Reflective Insulation Foil :
Is this a good way to insulate?
Zelfklevende Reflecterende Isolatiefolie Met Dubbele Laag Noppenfolie Geschikt Voor Huisfolie Wanden Daken Vloeren Zolders Garagedeuren Camperkassen(Size:1 * 15m(39in*49ft)) : Amazon.nl: Klussen & gereedschap
www.amazon.nl
