@DaveF what parameters (other than slim line looks) and priorities did you base your decision on for these tyres ?? As in, I'd be interested to know your decision criteria....
@DaveF are your rims 20x9 ?? Are you running B14's at -50mm ?? .... be interested to see any side on pics you may have of your van to see how it sits. Also pics from the back to see if the drop from 275 to 265 makes it less 'chunky' from the rear.
Mine is down at Bognor now for some 'stuff' and I took the opportunity to take out their B14 / H&R anti-roll bar van. Their's is beyond remarkable and mine is already good with -40mm Cobra's on. Ollie said the same to me. If I go the B14 way, I'll need to change down to 265, which would put my tyre research back to the beginning again, as it's not the most popular of sizes with a 40 profile in a 20" with > 103 load rating
@DaveF ....... Mmm thanks a lot Dave. Like that a lot. For my taste, that is aesthetically the perfect body shell drop to tyre gap
I guess at -45mm you've had no wheel arch rub situations with your set-up ?
If they can set mine to about -40mm, the extra weight of 4Motion, LWB, DSG might put the actual drop somewhere between -40mm / -45mm on mine and I could then possibly stick with my 275/40/r20 tyres. I'm still at the ringing around point to gather views on B14's on 4Motions (see the aggro with that in the other thread on that subject) AND whether B14's can be set at their apparent minimum of -40mm drop and still give all the expected B14 benefits on my rig
H&R ARBs work just as well on T32 as well as the lessor weighted models. They are a great upgrade that lighten the steering and further increase the steering feel and driveability - even more car like, and obviously reduce the roll. I run a demo fitted with these, anyone is welcome to come down and test.
