Live feed from the leisure side to the head unit?
GavMc P11GT
Hi folks thanks for all the helps so far.
I’m back oem (ish)
We now have a composition media head unit
Vibe powerbox amp and a vibe sub all fitted and working. (Better than expected too)
Dab issue is fixed
CarPlay is almost fixed awaiting a part
Lastly on my kenwood setup I had a switched live feed from my leisure system that would power my headunit when we are camping so that I never had to leave the keys in the ignition and the radio would just stay on.
The power side of things on the standard harness is not easy to understand so I wonder if anyone knows if this can be done? I thought I would be able to utilise the vibe harnessing to add this rather than digging into the van wiring system.
Any tips would be appreciated.
I’m back oem (ish)
Dab issue is fixed
I bought a kit from @Absolut5 for my Kenwood headunit to operate from my leisure battery as you require. Drop them a line with head unit details. If they can, they will certainly do so.
I had it all set with the Kenwood but have gone back over to oem+ have the switched live feed already behind the HU just not sure where it would fit in on a OEM HU as they are wired differently.
I am sure the boys at Absolut5 will be able to furnish the information you require. Just give them the details of the OEM head unit and they will advise if the mod can be done
