Knocknacross
Hi. Hope it helps someone. Wanted a permanent positive feed for my Dash Cam in the rear window. (Have one from the fuse box at the front) Access to a permanent live feed from the 12 volt charger in the rear seemed difficult without the charger removal tool. Access to middle charger permanent wires was simple. Just popped off the ventilation grill, peeled back the insulation tape from the 12 volt charger wires. Red positive/brown negative. I have fitted an anti flatten battery extension with a fuse on the positive feed. Works perfectly with no wires showing until it emerges at the hatch.
