Lithium battery upgrade
DarrenB83
Hi All, first post from someone who's not all that clued up on campervan electrics, having very recently purchased a new to me T6!
On first outing, it is very clear I need to upgrade my electrics to suit our needs. It appears my current setup is as follows;
  • A terrible lead acid battery
  • 200W solar panel with Victron SmartSolar charge controller 75/15
  • BCA PS167-13.8-BCSM power supply/battery charger
Based on the above, I assume I would need the following to accommodate a lithium upgrade that will suit;
  • Lithium Battery (looking at 300Ah)
  • 50A DC-DC Charger
  • 2000W Inverter
  • 240v Battery Charger? Not sure if this is needed, but it is in one quote I have obtained.
I have had a couple of quotes so far, and while I appreciate there's a fair bit of work to do, best quote is coming in at circa £1,600. Is this an expected cost for upgrading to lithium (with the addition of an inverter - wanted to power an air fryer & occasional nespresso)?
Appreciate any input on this, as I am lost as to what is actually required, and what costs I should expect vs current quotes!
Perhaps you could also compare with an Ecoflow, Bluetti, Anker, Jackery etc as another option.
Note also - check the cycle count for the lithiums. The newer LiFePo4 ones do around 4000 cycles
