Leisure battery earthing.
Unconcious21
Hi.
I am just running through my battery VSR cable and my under bonnet hook up cable.
My next task is to earth the leisure battery.
A friendly electrician seemed surprised that I would want to earth it to the body. He would rather run a cable from the starter battery instead.
What is the consensus of the forum regarding this. I was going to use the point beneath the drivers seat. Or maybe the very meaty cargo hook bolt? (T6 2019)
many thanks in anticipation
Aidan
Thank you again Deaky.
Ok that's clear Body earth.
Re the VSR I was lead to believe the Charge to Charge converters were a lot of money and that a VSR wouldd be fine and cost a lot less?
If I go for the Charge converter do you have a model in mind?
100% body earth.
The alternator in your van is designed to keep your van battery 80% charged, this means a VSR will only ever charge your leisure battery to 80%
There are loads of DC-DC chargers to choose from. Have a search on here, there's tons of info
