Firstly, for anyone about to fit a leisure battery under the passenger seat of a T6 and requiring a DC to DC charger I cant recommend enough getting the bits from Travelvolts, not only does he give you proper no bull advice he also provides a full kit with all the pre-wired cables bespoke to where you intend to fit your fuse box etc, (mines in the rear of the van).
Anyone interested in my installation let me know and I will upload some images.
I have also incorporated a panel mounted digital multi meter with the shunt wired in and set at 50 amp.
My question is:
Currently the only load on the leisure battery is from 4 x LED interior lights to the van rear with the leisure battery being continually topped up via a solar panel on the roof and PWM, float set at 13.8 etc.
With the 4 x LED's on I don't see any power or amp readings on the display at all, am i doing something wrong or just not enough load for it to register?
I will shortly also be fitting USB charging, more lighting, night heater and fridge etc.
Cheers Guys and Gals
My question is:
