Kiravans RIB Seat Swivel Install
moodsterT6
T6 Caravelle - Day Van - Occasional Camper
Completed the seat swivel install in our T6 Caravelle. We brought this one:
We also brought the raising shims which enable the Leisure battery to fit upright and to be able to retain the factory seat base trim:
FC0B91E6-95B6-4BAC-8A7E-8ACE32C5A991.jpegE89A2E21-E435-4922-9D2C-0F9E59F942C6.jpeg034C7019-2065-41ED-980A-0421B916AE9C.jpeg
The seat fairing had to be cut to enable the seat to be fully lowered without catching and deforming the fairing. Marked the position with some tape and used a scrap piece of ply to keep the fairing still whilst I drilled it:
DB73585C-47DD-4DB6-B87D-5670358DEBAC.jpegAAD6F639-90A4-4224-869B-E024409CB4B8.jpegD2EDD917-2E51-4E22-9593-222AD2987104.jpegA5941535-6BD5-4089-8333-100DA666A58B.jpeg
The trade off to not cutting the seat fairing all the way along, is you need to raise the height of the seat to slide it. That’s not an issue to us but could be for some.
Added some split loom to the airbag / heated seat wiring to protect them from the swivel mechanism
Seems to work well, so far no rattles or any noise the all (Yet). The shims do raise the seat a little to high even with the seat fully lowered. It’s fine for me and I’m only 5ft 5 but my wife who is only 5.1 her feet only just touch the ground. Might need to make a small foot rest for long journey, perhaps just some 18mm ply covered in rubber matting. We’ll see how it goes.
I recommend watching the Kiravans video on how to install the swivel, it’s very good:
Nice guide.
Didn’t order the shims as I don’t have a battery under the seat in the Velle. The rear base trim is easy enough to cut down to fit and reattach
drilling the hole for the handle is a nice touch
Nice guide.
Thanks, since I posted this I’ve actually cut the trim all the way to the rear to enable the seat to slide forward / backwards without needing to raise the seat with the height adjuster. That got pretty annoying very quickly!
Haha your passenger isn’t as fussy as mine then!
I move it 1mm = trouble is brewing
Hi There i appreciate this is an old thread but i was just wondering where you got the door pocket mounts for the usb chargers from? and also the plug sockets that fit in the original trim they look like a nice smart option.
Hi, The USB sockets in the seat side trim are these:
The sockets you can see in the rear seat bases are C-Line surface mount back boxes:
With C-line switches / sockets etc.
Cheers.
Hi @moodsterT6 the set up looks good, however, what happens when you need to move the seat forward or backwards for other drivers now you have cut a slot in the seat fairing?
Hi, Does anyone know if the raising shims can be used on the drivers seat? My leisure battery is under there and the extra 18mm would allow it to stay there.
Hi, Have you accounted for the hand brake height? I have not fitted a swivel to my drivers seat due to needing to modify the hand brake height.
I was planning to fit a new bracket and lower the handbrake at the same time. But if it turns out I’ll need to move the electrics as well (if the shim doesn’t do the job), I’ll probably stick with just the passenger side for now.
I’m assuming the shims do work as intended — the bolt layout looks the same on both the driver and passenger sides (although I haven’t tested that myself).
