Key Live - For aftermarket radio
superchargedpolo
Has anyone worked out if there is a suitable 'key live' in the T6 wiring loom. I have wired a number of T5 and T5GPs and you could splice into a green/black wire. This stayed live until you pulled the keys out. Great for an aftermarket stereo install.
I have a wee amp to install on a standard head unit and need to give it a key live as well as a permanent live.
Thanks in advance
Craig
Thanks in advance
Craig
Hi Craig
You can pick up the brown/green behind the fusebox like the T5, but I suggest using a auto turn on device which gives a slight delay to avoid pop on noise and will also work when you don't have the key in, so you can listen to it whilst sat up
Hi Craig
Jason, what gives the auto-turn on it's power? Is it some kind of physical switch?
