Afternoon
T6 has just started this behaviour - headunit comes on upon fob door unlock.
It’s an aftermarket Sony connected via a CANBuS adapter from Jason at Absolut. It’s been working fine for at least a year. Used to be the case that HU would be off until first stage of key turn. Now it comes on when unlocking, and goes off with locking.
Bit of an issue soon because I’m not sure I can rely on the family to manually turn it off if they open the doors and have picnic etc. could easily result in a flat battery.
I have installed a DSP and sub recently, but they’re powered by the leisure battery and I’m using a remote signal from the back of the head unit, tapping into the red wire. I unplugged the remote wire to double check there wasn’t some back emf but the behaviour stays.
I’ve checked that continuous and switched power are OK and the right way round at the back of the HU.
I also noticed that the van locks itself if the key is not inserted after 30s, despite drivers door being opened and then shut, which may be connected. Door microswitch seems to be OK cos the door open warning on the dash responds as expected to the driver’s door being open / closed.
Have disconnected the battery for 20 mins, factory reset the HU, to no avail.
VCDS not much use since it needs ign to talk to the BCM.
Unlike the Kenwood, there are no settings to control this behaviour on the Sony.
Am a bit stumped. Only things that I can think of are:
Many thanks
- ECU reset through cap discharge
- Swap out the Canbus adapter
Many thanks
