Kenwood 8021 and PDC sensors
nsweatman
I’ve recently purchase and had a Kenwood DMX 8021 DAB at Halfords. The old standard unit had rear parking sensor come up on screen. Now with the Kenwood that as gone. So before I go back to Halfords asking, I just want to make sure this isn’t correct and the parking sensor should show on screen when I’m in reverse.
Depends what adaptor you have from the original wiring. I have an 8021 from @Absolut5 and the sensors work and show up on the screen and as audio.
Does it come up with the camera instead when in reverse ? I had to change the settings in the stereo to turn off the camera as I don’t have a camera .
I’ve not got a camera fitted yet so it might be a settings thing. All I have is the factory reverse parking sensors
They wouldn’t have used the correct adapter,
They may also try to install a connects2 infoadapter at will display them through the reverse camera port, refuse this as its graphical poor ,
We only use genuine Kenwood interface to play display through the CanBus input port
If Halfords can’t correct this issue how much will it cost me if I took it elsewhere to be sorted?
The part alone is £150.00 , cannot comment on how much some would charge to install it, but you can do it yourself , it plugs straight into the vehicles qualdlock and into the back of the head unit, no extra wiring is needed, no coding, all you need is 2 tools , one to remove the trim and a screwdriver
I’ve just got the kenwood for mine, it came with the connect2, my rear camera is not working? Is that due to the connect2 not right? What do I need to get it working? Genuine kenwood? Is so where do I get it from
What camera is it ? Does it have factory parking sensors ?
You will need a camera adapter that plugs into the quadlock , we keep stock all the time
Does your parking sensors show up on the Kenwood ..?
Nope but it used to on the old standard unit, I saw online it does with the Kenwood hence I got that one, could you let me know how I can purchase from you
We keep stock of the correct interface to display the sensors (picture below shows where it plugs into)
and retain the camera
Drop us a call on 01980 624740 to order
Highly recommend Jason @Absout5 for all your ICE. Very helpful after Halfords supplied the wrong interface. All up and running now Thanks Jason
